Swapping my 4.2 block for a 4.0 block
Dougie87
South Carolina
Ok, I'm at a crossroad of changing my 4.2 block over to the 4.0. I did a 4.0 head swap on my 4.2, and I found out from the shop, that I may be leaking oil from the back of the block. I have not gotten it home to break it down and see yet. My question is, I have the 4.0 head, intake and exhaust from the swap, will the 4.0 replace ok if I get the bell housing to mate up my AX15 tranny? I'm looking at short blocks right now but wondered if someone out there has done this. I know I will like the extra horsepower.
Wasn't planning on it. My head conversion was with a 2150. I would like to have evidence, but cost is a factor.
The block isn't what gives the extra horsepower...the EFI and tuning is what does that. You're probably better off just fixing the oil leak if that's an option.
I'm going to tag @NovakConversions since they'll know for sure.
I appreciate the confidence but we don't actually get into the 4.2 or 4.0 much at all aside from maybe converting to a different transmission. I'm not much help on this one. Sorry guys.
-Dustin
That's what I think too, we'll find out when I can get to it. Thanks for the feedback, that's the course I'll probably take.
also check the valve cover gasket. I had a cork gasket in mine when I bought it and that leaked within a year. The leak looked like a RMS. Use one of the good rubbery steel fel pro or victor reinz ones if you can.
