Starting issues
Hawk93
California
First time poster long time reader here. I have a 92 yj and it’s got some weird issues when starting. A couple of weeks ago it refused to start after a quick stop at the store, and I thought it was a battery issue since no lights came on and there was 0 action when I tried to start it. Had a friend come jump me and still nothing. As soon as i disconnected the jumper cables I decided to try it one more time and it fired right up. Fast forward to today and I went to start it and again no lights came on and wouldn’t even crank. Battery, starter, and alternator were removed and tested (came back good) so I reinstalled them and the dash lights came on but when I tried to start it I got a singular click from the starter, when I tried to start again there were no dash lights and nothing happened when attempting to crank. First thought was a grounding issue so took all the ground points off and cleaned them up really well and still the same result. I eventually found out that if I disconnect the battery between trying to crank it the dash lights come back on and I get that click from the starter. I’m at my whitts end. Any advice? Thanks!
how old are you battery cable. you wrote, when you move battery cable you get effects, stick or automatic /does your battery have full charge?
New battery cables, connected correctly, it’s a stick and the battery is fully charged. I ended up making some progress late last night. On one of the wiring harnesses coming out of the steering column there was a random jumper with an in-line fuse which was blown. Accidentally pulled the other end of that from wherever it was attached and it’s been starting right up ever since. I can’t figure out where that wire ran to, but everything is in working order 🤷‍♂️
