Rear drive shaft death
ShawnM
Oliver BC
Driving down the high today my rear drive shaft committed suicide. It went flying off and I found it but it’s too dented to ever get new u-joints into it. I limped home in 4 high, front wheel style. When I got home I saw the front yolk that goes into the transfer case was gone too.
I look on Just Jeeps, Rock Auto and Amazon and all the rear shafts are minimum 16” long. Mine is 12 3/4”. Is there that much play in the slip yolk or what am I missing here?
I’m no mechanic but I’ve changed a shaft once and get how to do it.
No, it just happens that nobody makes a replacement for the shaft you have. I’d search for used on eBay or maybe go to a local driveline shop.
The reason you busted the shaft is probably the lift. These tiny driveshafts don’t like any suspension lift.
Reactions: ShawnM
That’s crazy that they don’t make replacement shafts. Off to eBay I go I suppose. Do you know offhand if the replacement yolks are the same?
Not sure I understand what you’re asking. The slip yoke that slides into the t-case is the same across all years. Spicer 2-3-12411X
The rear driveshaft has 1310 sized weld yokes on all 87-93 rear driveshafts. 94-95 use a 1310 weld yoke at the t-case end and a 1330 yoke at the pinion end. Those of course correspond to 1310 and 1330 pinion yokes on the rear axle from 87-93 and 94-95, respectively.
The front driveshafts are all 1310 on both ends for all years. Transfer case front yoke and front axle pinion yokes are the same models respectively. What I mean is the t-case uses the same front yoke year to year and the front axle uses the same yoke year to year. I do not mean the front axle and t-case front output are the same yoke; they are not.
You are very knowledgeable about this stuff. Yes that helps knowing that t-case slip yolk is at least going to be easy to get.
It looks like everybody that ever had this issue got a slip yolk eliminator kit which requires a longer drive shaft. The angle of the shaft is less, making for a much beefier set up. This ain’t gonna be cheap.
