Ratcheting noise
Brush Beater
Roseburg Or
89 yj w/ax15 (NEW) NP231 (REBUILT), hpD30 front w/ new carrier & 4:56 gears and bearings, d35 w/New carrier and 4:56 gears and new bearings, posi lock delete w/ collar locked to axles. my problem is in 4low 1st gear I get horrible ratcheting noise that disconnects power to front axle. Sounds like splines and coupler not quite messing and kicking out under high torque load The more torque the worse it is.it will do it in 4high not nearly as bad. i'm thinking transfer case but would like some input from someone smarter than me!!
update to ratcheting noise in yj. Two wheels off the ground (open diffs) transfer case in 4 low, 1st gear and let the clutch out and front drive shaft chatters and wont turn. took shift linkage off and transfer case shifter can not shifted any further. internal problem? shifter select falls into each detent ( 2h, 4h, n, 4l)
that good you let us know what was wrong, i wished more people would do the same, good luck and safe driving.
