No Oil Pressure: 1992 Jeep YJ 2.5
RayGilSr7
Louisiana
So I'm lost! 1992 YJ 2.5 No Oil Pressure at Idle and low at drive. Has new crankshaft, bearings, oil pump, pickup, sending sensor, K&N oil filter, spark plugs, cables, oil pan gasket, Mobile 1 10w30 High Mileage Full Synthetic and No leaks anywhere. Any Suggestions would be GREAT!!!!
If you are going off of stock gauge, try using a mechanical gauge to see if the reading you are seeing is correct.
Agreed, the stock gauge can't be trusted that much. I'd get a mechanical gauge go get a real accurate reading first.
