No Brake Lights
jeepjoey
Pensacola, FL
My brake lights stopped working. The running lights, turn signals, and flashers all work, so the bulbs are good. The fuse is good, and I just replaced the brake light switch hoping that was the issue and it wasn't. It seems I have a gremlin. Anyone else ever had a similar issue? If so, how did you fix it?
1994
I would check every ground, when everything else checks out it going to be a bad ground.
I would pull the harness to the tail lights, have someone press the brakes, and make sure you're getting voltage to the tail lights on the brake light wire. If not, then either that new switch is bad, or there is a break in the wire.
