My jeep wont start
Ezekiel Cheek
CA
My jeep broke down a while ago and wont start. I had the clutch replaced just before and I noticed after it broke down that the people left the bleeder line open on the transmission fluid. I refilled the transmission fluid and took my jeep to the shop after I couldn't figure out what was wrong but the shop couldn't figure it out either. They thought maybe It could be electrical and I think it could be too since I found a few nests in the jeep when I got it but the previous owner made a few modifications so I don't know where to check.
I assume you men the clutch master and slave bleeder line they left open. If the same shop that did that you might try another shop for the starting issue if your not up to the challenge. Wont start as in wont crank over or cranks over but wont fire up? Clarify that one as it will make a difference as to where to look as there are numerous things it could be.
yeah they left the line open on the slave cylinder. The shop that did the clutch was and the shop that tried to get it to start are different shops and the engine cranks but doesn't quite start.
