I need some help or advice. I bought a 1995 YJ awhile back I have since put the motor (4.0) back together and back in the jeep. It has new distributor, new throttle position sensor, new IAC valve, new crank position sensor new O2 sensor, new battery, new injectors, new ECM. I can’t seem to get it to get spark or anything all it will do is turn over. When you first turn the key it’ll click the relays but a couple secs after that they click off I’ve tried switching relays I’ve replaced fuses. I’m stumped I don’t know what else to do
Any help would be appreciated thank you in advance
