YJ rear disc brake upgrade
gwood804
Alabama
I'm upgrading to rear disc brakes on my 92 yj and was wondering what needed to be done about proportioning valve. Does it have to be changed, if so, what valve do I use? Also do I need to change master cylinder and if so, what master cylinder? Any help would be greatly appreciated
No need to change anything if the disc brake setup you’re using is TJ or Ford 8.8 sized or similar. The factory rear disc TJs used the same combo valve and master cylinder regardless of disc or drum.
