Idle Control Query
jpjeep26uk
UK
Hi from the UK, Really dumb question but I removed the device in red as I thought it might be the culprit of my high idle - 1400rpm even when warmed up, sits there all the time- stripped it down and cleaned a lot of crud out of the gear mechanism and gently cleaned the little motor which was a bit carboned up and then refit it, which was a PITA as there is a strong spring stopping me from just clipping it back together.Anyhoo, what is it called as it made no difference at all so I'm going to buy a replacement, but don't know it's actual name haha. Also,how far out should the little screw be? Someone said don't touch it so of course I did. I undid the battery for hours to reset it but alas, no dice. 1400rpm Idle when warm grrrr!
