Have the Dana 30 front axle apart fixing the inner oil seal leaking on the drivers side. Got that one set with the seals inner spring facing inward toward the carrier. Went to set the passenger side in the the axle
tube right of the access panel for the FWD fork with the inner spring facing the carrier and have destroyed three trying to press it in. Saw a YouTube with a guy that used all thread to draw it in from the hub side, But he had the inner spring facing to the HUB side. Am I missing something? The seals are different diameters and I did slide the seal over the axle and it was correct. Can anyone smarten me up to this? I’m a long way from home and the Wife ain’t happy with me thinking I’m making this up to hang with my Buddy……And I’m running through what’s available seal wise at the parts houses…….
