The radio and outlet was working until fairly recently according to the owner. The wiring looks rough and the radio that was in it I can tell has water damage and probably no longer works. I want to check and see if the fuse is okay to start going through it. The manual says the fuse is number 10 but I am seeing where it says radio in the bottom left corner and I don't know what that slot is for. So any tips in starting and what that part of the fuse box is I'd appreciate the help!
This is an 89 with the 4.2
