Help with lift and shocks
Justinandkelly
Lake wales, fl
I have a 87yj. It has a lift. I have 33s on it. Can you help me determine what size lift it is and what shock size I should buy? The shocks are trashed. The bump stops are gone. It has the metal additions on the axle tubes that are supposed to hit the bump stops.
Based off the pics aid say its a 2.5" kit, not 4". Are there any numbers on the top sides of the spring packs? Far as bump stops Im gonna say most of us with 2.5 kits just run the factory stops and were fine, me included. Id also add the shocks likely have a part number stamped on the body down at the bottom. That will tell you some info as well.
