Heavy Duty Steering
Ben Venner
Michigan
Hello all, I'm working on updating my steering on my 95 YJ. I am going to use a kit from RuffStuff. The kit is a one ton kit that uses GM one ton tie rod ends. The kit requires me to cut my own tubing that they send, and weld in the ends, which is all fine. If I decide to mount the tie rods under the knuckle in stock configuration, I will not have to bend my tubing, whereas over the knuckle I will have to bend most likely. So, my question is this, are there measurements for the lengths of the tubing for the drag link and the tie rod bar, or am I better off measuring my stock one and going from there? if there's already a thread on this, I apologize, please point me in that direction.
Thanks,
-B
