Gear selection bulb
cameron.rw
Bridgeport, OH
I was switching my dash lights and I thought the bulb for the gear selector would be the same... it isn’t. So whatever bulb it is I’d appreciate the advice! Also with the bulb for the climate control I do not know the size for.
In the past I've read that corrosion is often a problem so it may not be the bulb. I found on user say it's a #37 light bulb but I'd take it with me to compare it at the parts store and keep that sleeve. They're hard to find and you'll need it.
Yeah I believe the manual says the bulb for the "auto trans. indicator lamp #1445". It doesn't seem to match, #37 would probably be the closet, is that the same as in the e brake indicator? The bulb was working before I took the cover off but now it isn't working. I haven't pulled it out yet because I couldn't figure if it needed to be twisted.
