Full body mount kit recommendations for 95 YJ
Puchito84
Pensacola, FL
How’s it going everyone!! Looking to finally replace all of my body bushings on the 95 YJ. Hopefully I get all the bolts out without snapping them. Does anyone have any recommendations for polyurethane body mount kit (stock height) I would like to get all new sleeves and bolts while I’m in there. Red would be great but not a must. Also would like to know what sleeves to get and how many as I believe they may be different sizes as well as the radiator one. Don’t want to order the wrong ones and prolong the job. Any help would be greatly appreciated.
Before ordering anything I’m going to spray the bolts over and over and see if they come lose before I even decode to do it. They ones In the Jeep look to be original and Jeep doesn’t really have any rust anywhere so hopefully that’s a good sign. If they all come loose new bolts are definitely getting anti seize on them.
Looking for a good set but also don’t want to break the bank since I want all new hardware as well. Thanks for your time jeepers!!
I don't recommend body lifts. Suspension lifts are the way to go, and this is why.
Dang yeah that’s a hell of a repair. Was looking more so to replace the body mount bushings stock height. I already have 2.5 inch leaf spring lift and shocks. I got all the bolts off except two. One I’m still working on getting out and one snapped so I’m going to have to do surgery and drill out very carefully and tap it so I don’t have to cut it out. Still trying to decide on a kit. Poly or rubber. I would really like red poly but I’m all ears. What are your thoughts
Thanks. I just ordered the stock rubber mount from crown automotive with all new hardware. Snapped one boat I need to drill and tap patiently and the one that seems like it’s seized. May try to apply some heat to the bolt to see if it will losen so that I can get the new ones on lol
Yeah, those bolts will get you. Let me guess, either one of the rear mounts or the one just below the footwell?
