Who won, first I want to say thank you to anyone who even gives this a thought because the struggle is so real right now. It's been about a year, so I can't even remember what initially happened to make her stop running, but I have a 1991 2.5 L four-cylinder she refuses to start.
Okay the problem I'm having is no start, no spark, no fuel pump.
Simple enough to solve, but here's the fun part; this is what I've done so far: I reset the timing to top dead center by putting my finger in the spark plug number one hole and turning the camshaft police until I felt the air and then stopping at zero and the rotor was in the 5 o'clock position so I figured the timing is good, I bought the factory service manual, I've replaced the computer, alternator, starter, crank position sensor, ignition, coil, distributor, wires, spark, plugs, and the battery. I've replaced every relay and fuse, I have removed the wire harness from the engine compartment and the cab and completely went over the whole thing, fixed all connections, cleaned all of the grounds, for reinstalling it I checked assistance from every wire connection to its origin location and then once I installed it, I checked proper voltage on every connection, including the fuel pump and everything is as it should be. My tachometer also isn't moving when I'm trying to crank it which tells me the crank sensor is bad although I just replaced it so I'm going to warranty it and get another one, but i'm also not getting any spark from the ignition coil so I checked the wire that goes from the coil to the computer and that's good.
Not kicking on when I turn the key on has me so bewildered because I'm getting power to it have a good ground to it. The sensor wire has no resistance and I jumped it from the battery and it worked so it's not a bad fuel pump. Also change the relay and the fuse and when I turn the key, I'm getting, the right voltage to the power distribution center, so I have no idea why the fuel pump won't turn on. I am ready to pull my hair out because I've literally been going in circles around the smallest engine ever and I cannot figure it out. It's probably something right in front of my face , but I'm missing it so if anyone can help that would be amazing.
