Greetings,
What would you do?
A) get an ODB1 scanner and continue down the rabbit hole? or
B) throw in the towel and take it to a mechanic?
I've owned my garaged 95 YJ for 16 years and have loved it since day one. I've done almost all of the work on it and it's in excellent shape (my dad is a mechanic). The problem? It must have heard whispers that I was considering selling it and now it's pulling a Herbie on me. Clearly, it does not want to be sold.
A few times recently, it gave me a check engine light (super surprising). The flashing light sequence indicates code 27 for an Injector Circuit malfunction. It's intermittent.
* The injector plugs are receiving both positive and ground (used a test light). Removing an injector plug will cause a rough idle and an immediate CEL.
* I put seafoam through the intake, independent of this concern, a couple of months ago (four-hole mustang 5.0 injectors have ~50k on them).
* I popped in a new relay into the Auto Shut Down relay slot (no change).
* If I disconnect the battery, it will usually show code 27 prior to starting. The CEL stays off after restart.
Poking around the engine bay while running, I can occasionally hear it drop a cylinder while pushing/pulling on the wires on/adjacent to the injector rail. It is not consistent though. No single push/pull anywhere will cause a reproduceable response. I really do not want to rip into the wiring harness as I'm concerned I could end up with a litany of other issues.
I have spent a ton of time with the vehicle this year and have finally finished all of the projects I had been dreaming of over the last decade. I'm just not sure what to do next. I have no interest in playing guess-and-check with a pile of parts swaps (definitely not if I go mechanic route). The engine bay is CLEAN. It's never been mudded or abused in any way.
Thoughts?
What would you do?
Thoughts?
