Can anyone help me identify the wires in this picture that goes thru the firewall?
CLBeam
Kings Mountain, North Carolina
Can anyone help me identify the wires in this picture that goes thru the firewall. Need diagram or wire color and what they do. This complete harness was inadvertently removed and they cut these wires. They stripped wires from the harness not needed for a swap.
C91 18LB - AC switch sense
C21 - 18DB/YL - AC select
A1 - 12RD - fused battery power
G4 - 20DB - fuel level
G20 - 18VT/YL - coolant temp
X3 - 18BK/RD - horn relay ground (from steering column)
G1 - 18DG/GY - 4wd switch sense
L1 - 18VT/WT - backup lights
G60 - 18GY/YL - oil pressure
A41 - 18YL - ignition switch power
thank you Machoheadgames. now I can follow diagrams and straighten all this out. Thank you sir.
No problem. Good thing is none of those are critical to operation except the 12ga battery wire which goes to the ignition switch.
