A/C problem
Rdb533
Texas
I have a 93 yj 4cyl 2.5L and I'm getting conflicting reasons with an ac problem. One per person say compressor (more expensive to buy but easier to replace. The other says expansion valve (less expensive to buy but harder to replace). So, either way I'd like to try to narrow it down if I can. I have a set of gauges that I'm still getting used to but want and need to get better with them having 2 old cars and very limited funds.
My Jeep has an under dash ac that was there when I purchased it. OK, issue is, ac not cooling which worked one day then went out the next day and not cooling and when I put the gauge on (engine off) I have about 40psi on both low and high.
The system had been flushed and dryer and seals were replaced. After trying to introduce refrigerant both the low and high side went up to about 90psi (engine and ac on). From what I do know the low side is to high and the high side is low. The other thing is that under the dash right by the expansion valve (with ac on) I hear what I'll call a noticeable "ticking" noise.
When I have the ac fan on and turn the cooling knob off the sound goes a way so it's not the fan motor. I would really appreciate any help and any layman instructions on how to proceed with trying to diagnose which one might be problem or what else it might be.
Check that the compressor is actually spinning and it's not just the belt turning. There is a relay for the compressor. I'm not familiar with the Jeep ac but these are just basics. Do you see any bubbles moving in the sight glass on top of the dryer?
