93 YJ won't start
SkipB
Ivanhoe Ga.
Guys my 93 wont start it acts like there is a clutch safety switch but I know the 93`s don`t have one. I can turn on the switch and everything works like it should but when I turn it to start there is nothing. I can jump the starter with a screwdriver and it starts just fine. This leads me to think there is a dirty or corroded terminal somewhere. The lock cylinder works like it should although it is a little stiff. Any suggestions
I’d start by swapping the horn and starter relay to see if the starter will start then. If not then possibly chasing a wiring/corrosion issue or a bad ignition switch on the steering column.
you might also check your battery cables, some times they go bad inside, places we dont see.good luck
