Hey All! New guy here but long time reader. Been doing a bit of work on the jeep lately and I can’t figure this one out. Any help is greatly appreciated!
Saw a small fuel leak by fuel filter and was running rough with a very low idle. Replaced fuel filter. No dice.
The gas tank skid plate was rotted so I figured I’d get a new one, do a new fuel pump, run all new fuel lines…and this would fix.
Finally got that bear of a project done. Issue persists. I never looked for a CEL as the fuel leak was a physical clue. I should have though. That was bush on my part.
Today I checked and it was throwing a Code 14: MAP sensor circuit open or shorted; voltage too low.
I checked for the 5VDC at the MAP plug and it was there. So I replaced the MAP sensor with one from NAPA.
Now the jeep wont start at all. :/ I ohmed out all fuel injectors and the are all good. About 14.6.
Any one have any insight? Maybe vacuum leak?
