92 YJ - Left Brake Light Only Works After Turning on Left Turn Signal
jeepformyboys
Bandera, TX
Replaced taillights with LED lights/housings. Hardwired into original lighting after testing. After a few days I noticed that the left brake light only worked after turning on the left blinker. It quits working when the left blinker is activated again and cycles back in forth in that manner. All blinkers work. All hazards work. Parking lights work. Only other thing different from the right taillight is that it has the license plate light. Installed new EL12 flashers. Checked ground. At a loss as to what to do.
Bad turn signal switch. It directly controls the brake vs blinked feed going to the high side of that lamp to differentiate between turns and stopping. If it’s not solid when braking, then that portion of the turn signal switch is probably corroded.
