2.5 power steering pressure switch
Jpuga
Delano
Anyone know where in the world I could get a power steering pressure sensor/ switch? I’ve looked oreileys, Napa,autozone, carquest, Amazon, ebay, rock auto,summit,4wheel parts, and the list goes on…. My switch is broken. And my check engine light comes on and off. I assume this is the culprit. Can I retrofit a switch from a TJ??? The pressure difference can’t be too much if any between the two. Anyone know if the TJ is normally open or a normally closed switch. I believe the yj is normally open.
No check engine light anymore. my 02 wasn’t plugged in all the way. Haven’t checked for codes I seen it broken thought I change it and. Jeep runs good. I seen one that looked similar on rock auto and it was labeled as a oil pressure switch and had a bunch of different part numbers I did some digging around and traced it back to the original part number for the power steering. Let’s just hope it was in stock although it said it was…. you just never know if the guy updating inventory went on vacation……
