Ideas please.
1992 4.0 Oil pressure gauge not working. Gas gauge, temp gauge and Voltmeter all work.
I have replace the gauge and the sender. I have cleaned both grounds under the hood. I have also pulled the cluster and cleaned the copper contact points.
Anyone want to talk me thru using a multimeter to see if the wire is bad between the cluster and the sender?
Also it is my understanding with regard to the 4 gauges in the instrument panel running off the circuit board, if one gauge works then that tells my the circuit board is ok. It’s an all or none type thing. Can anyone confirm?
Thanks
Thanks
