1990 YJ Gauge Cluster
JAM1756
Seguin, Tx
1990 YJ-My gauge cluster stopped working.
* Checked the gauge fuse- it is good.
* I have removed cluster and cleaned the circuit board
* Cleaned the engine ground wire connection
* Replaced the gauge cluster lights- they all work
* Checked the voltage to each gauge using a test light. I have current to the positive terminal on each gauge
* connected a ground wire to the ground on one of the gauges to see if that would work- didn't
* purchased a new oil pressure gauge and replaced to see if it was the gauges. Didn't work. ( I spent $120 with a mechanic that told me the gauges were all fried)
Where am I- lights all work in gauge cluster, no gauges work. Clock does not work.
ANY IDEAS?
Sure seems like a printed circuit issue. I noticed the other day on Amazon that there are new printed circuit for the early gauges for around $20..no idea of quality but it might be worth a shot
