First time on this page so apologies if I don't do this right, I work on Cherokees and comanches mainly but took up helping my grandfather on this one.
1995 yj 2.5 manual
First symptom, randomly stalled, crank no spark, grandpa fired the parts cannon and replaced distributor (and connecting parts) cps and camps, coil, computer was sent away and tested.
By grounding the sensor ground wire to the battery I was able to get it to run but any throttle input stalls the engine
Second symptoms, stalling as mentioned, engine codes for every sensor over/under voltage and battery overcharge, battery shows proper voltage and is not overcharging, sensors show correct voltage and test fine except the TPS showing a jumpy sweep mid way through.
So my question lies, after three weeks of chasing harness and testing wires, where should I go next? I feel as though replacing the TPS is not the solution to all problems mentioned.
Appreciate any input, thanks.
1995 yj 2.5 manual
