Unknown no spark no auxiliary power
Solar_Jeep
Boone NC
I recently purchased a 95 yj Sahara with a straight 6 and the 5 speed, when I first inquired about the jeep it was running just fine, I have a video from the seller, before I got to pick it up it up we had a hurricane come through and water got under the hood (did not get shut before it started raining, did not get flooded) but got wet. Now when you turn the key none of the lights turn on from the dash, the starter is on a hardware switch and will fire, but with the key in run it will not spark and fire. Fuse 9 ignition does not have power. I put a wire from the battery to the fuse and (jumped it) but still no spark, rotor cap and ignition coil are brand new and still problem with old parts. I don’t know where else to look and what for. Ideas are welcome, thanks
