Tire Pressure
JaredMLowe
Florida
I am running 265 70 R17 BFG KO2
All stock suspension.
What is everyone running their tire pressure for daily driving?
Think you'll find that answer like should I use synthetic or not. my 91 is my DD when i need to go to town which is 15 miles each way. Cause Im lazy I leave my tires at 16 cause I off road several times a week. Would I use that pressure if im freeway flying...NO. back to 25.
Reactions: JaredMLowe
If you play around with some low pressures if you have time post your results. my 31's at 16 still only give about 70% of the tread width. Wouldent want to go any lower on pavement but on dirt Id like to go lower. Just dont wanna pop a bead off 40 miles from home.
I forgot all about the chalk test.
Last time I heard about that was when I was in High School auto shop!
Too low of pressure off-road with a Radial will likely break a sidewall before it comes off the bead.
That's why I don't, and won't have radials on a Jeep. (but mine isn't a DD)
Running bias-ply tires I can't recommend pressures, I run my TSLs @10psi street and 4psi off-road.
