Hello,
I recently purchased a 1990 Wrangler Sport V6 automatic, and I am working on changing out all of the fluids. I was all prepared to drain the transmission and replace the gasket and filter but ran into a problem with two of the pan bolts blocked by the skid plate. Is there a way to access the two bolts without removing the skid plate? I thought I should ask before taking it in for a service. How difficult is it to remove the skid plate? I ended up pumping out and replacing as much fluid as I could.
Any assistance would be appreciated.
Thanks,
Ed
Thanks,
Ed
