Hey guys, I'm having a strange issue with my 91 yj.
The rear passenger signal light and brake light do not work. Every other light does work. I've gone through fuses and relays and they all look good. I've changed the bulbs, and washed the 3 bolt grounds in the assembly.
I'm not getting power at the socket when I brake.
The rear right signal light works when I connect the red and brown wire to it further down the harness and close to the plug. But only the signal light. So I'm not sure if that means there's a brake in the wire somewhere or something.
I'm not sure how to proceed with this.
If anyone has advice or suggestions id appreciate it!
