i picked up a 94 yj (2.5, 5-speed) as a roller/project. Bought a running 2.5, 5-speed, t-case (heard it run before i bought it) and over the course of maybe 6-months or so finally got it installed.
While connecting all the wiring, i found some connections on the engine were different, so I bought new 94 sensors, etc and installed them.
Everything seems to be connected correctly.
All new relays under the hood, all new "max" fuses under the hood, all new fuses under the dash....
when i turn the key, normal pre-start warning lights come on, but turn the key to start and nothing happens, no click no nothing....can't hear the fuel pump kick on either
If i turn the key to run position, squirt gas in throttle body and cross the starter it fires right up and runs as long as i keep pouring gas in the TB.
I have replaced the ignition switch with a brand new one thinking that maybe the culprit, as well as cleaned all ground connections. Clutch slave seems to be full and working correctly (may need re-bled) thinking maybe a clutch/neutral safety switch and tried a few other little things. I'm out of ideas
Can anybody think of anything i maybe over looking? Engine runs GREAT when i cross the starter and keep gas in the TB.....no smoke, ticks, knocks, anything.....just can't figure out why no power to starter or fuel pump
Any ideas/input GREATLY appreciated!
