Help please.timing chain cover won't go back on
Dennistryed
I have a 91 YJ with a 2.5 I noticed oil leaking through the timing chain cover so I removed and went to AutoZone and bought new gaskets went to reapply the cover and the water pump will keep it from going on do I need to remove the water pump to put it back on how come I didn't have to remove it to take it off
Honestly not picking at you.....But the rule I stick to from experience is as follows, Auto Zone is only good for fluids, Filters etc. If you get into replacement parts/seals/gaskets for your engine and drive train, Pony up the extra and get them first from NAPA, And then and only if NAPA can't help in order, O'Reilly's
and then Advanced...
