Door rebuild parts
Whiplash2130
Florida
Bought 2 YJ doors today, who has recommendations for buying rebuild parts?
Yes, door panels, handles, mirrors and all rubber. The steel looks good and the glass and cranks work fine. I looked some on Quadratec and found two kits.
I stripped down the first door today. Found an area on the upper surround that has been previously repaired. Looks like they used some kind of epoxy putty over a perforated metal. Definitely will remove and weld in a repair. Also found the usual crack at the bottom of the vent window post, an easy weld repair. Going to have it media blasted, primed and painted.
I
Have you given any thought to posting your rebuild progress here? I would enjoy to see the process and progress towards, “like new.”.
Reactions: Whiplash2130
Ill
I
I’ll post what I can. Most work is being done by a 4x4 shop. In the mean time I picked a couple of used doors. I have stripped them down. This week I’ll be sending them to a friend of my son who does media blasting. When I get them back, a decision will be made as to wether they are worth fixing or not.
Reactions: Fouledplugs
Just picked up a YJ for my daughter's first car and can't unlock it from outside the driver's door. After opening it up I see it is missing the linkage between the lock cylinder and the lock mechanism. the linkage have a 90 bend at the bottom with a clip and an "s" curve at the top with no clip. From the research I've done I believe the OEM part number I'm looking for is 4797152. I've searched all over to find this but haven't had any luck. Can anyone here help??
A lot late to respond, but I goggled your number and it came up with a mopar parts overstock site that looks like your best bet
parts@moparpartsoverstock.com. They have some parts. My jeep has all/thread rod that the PO fabricated into the door
Sounds like the same piece I am looking for. I bent my own rod (welding rod) and got some plastic clips from O'reily's. But the piece from the cylinder to the rod is a tough one. Just discovered a salvage yard in South Carolina "Davies". Lots of stuff, but call them.
