Hello everyone I purchased my 87 about 6 years ago. It had at the time had an AX-15 installed to replace the Peugeot tranny. Initially there was grinding when starting. I have replaced the clutch assembly/ flywheel resurface and re-ringed. I still have the grinding issue between the starter and the flywheel. Has anyone else delt with this issue and if so what do you all recommend?
