89 yj no spark
kenn912
Utah
I bought a 89 yj with the 4 cylinder. The person I bought it from stated they put a new clutch in it and could not get it to start. There is no spark. It has a new coil, cap and rotor.Could he have done something wrong to the crank position sensor while installing the clutch? I checked the CPS and the ohms are correct
what does your code say. do you have a cel showing? make sure all of the wire are pluged in tightly. i would check to see if CPS is properly installed.
