YJ revs on cold starts
Mark
Texas
‘95 YJ started revving high off cold start, then “sucking” occasionally while driving. Cleaned throttle but still having issues.
Please help. My 1995 YJ started revving real high when I start it, then immediately levels off. But then when I shift gears, it appears as the throttle is stuck and it keeps revving up and accelerating by it self. I have cleaned the throttle body, and even replaced a broken throttle return spring, which I really thought was the problem. No luck. Any help
Mark
The throttle body has an electric idle control valve which tends to get gummed up causing a high and slow to react idle control. Inside the throttle body you'll see an oblong opening on the inside wall and be sure you get plenty of throttle body cleaner inside there. You can remove the controller and clean the little plunger too just don't lose the screws. It may need replacing it this continues after cleaning.
This is just my initial guess since I've had it happen several times.
