bytes_sent | 6602 |
bytes_received | 437939 |
packets_sent | 102 |
packets_received | 832 |
protocol_overhead_in | 3328 |
protocol_overhead_out | 408 |
bytes_received_ok_packet | 0 |
bytes_received_eof_packet | 0 |
bytes_received_rset_header_packet | 297 |
bytes_received_rset_field_meta_packet | 0 |
bytes_received_rset_row_packet | 114 |
bytes_received_prepare_response_packet | 62261 |
bytes_received_change_user_packet | 374837 |
packets_sent_command | 50 |
packets_received_ok | 0 |
packets_received_eof | 0 |
packets_received_rset_header | 33 |
packets_received_rset_field_meta | 0 |
packets_received_rset_row | 18 |
packets_received_prepare_response | 683 |
packets_received_change_user | 80 |
result_set_queries | 14 |
non_result_set_queries | 4 |
no_index_used | 0 |
bad_index_used | 0 |
slow_queries | 0 |
buffered_sets | 0 |
unbuffered_sets | 0 |
ps_buffered_sets | 14 |
ps_unbuffered_sets | 0 |
flushed_normal_sets | 0 |
flushed_ps_sets | 0 |
ps_prepared_never_executed | 0 |
ps_prepared_once_executed | 16 |
rows_fetched_from_server_normal | 0 |
rows_fetched_from_server_ps | 66 |
rows_buffered_from_client_normal | 0 |
rows_buffered_from_client_ps | 66 |
rows_fetched_from_client_normal_buffered | 0 |
rows_fetched_from_client_normal_unbuffered | 0 |
rows_fetched_from_client_ps_buffered | 0 |
rows_fetched_from_client_ps_unbuffered | 0 |
rows_fetched_from_client_ps_cursor | 0 |
rows_affected_normal | 0 |
rows_affected_ps | 0 |
rows_skipped_normal | 0 |
rows_skipped_ps | 0 |
copy_on_write_saved | 0 |
copy_on_write_performed | 0 |
command_buffer_too_small | 0 |
connect_success | 1 |
connect_failure | 0 |
connection_reused | 0 |
reconnect | 0 |
pconnect_success | 1 |
active_connections | 1 |
active_persistent_connections | 1 |
explicit_close | 0 |
implicit_close | 0 |
disconnect_close | 0 |
in_middle_of_command_close | 0 |
explicit_free_result | 0 |
implicit_free_result | 14 |
explicit_stmt_close | 0 |
implicit_stmt_close | 0 |
mem_emalloc_count | 0 |
mem_emalloc_amount | 0 |
mem_ecalloc_count | 0 |
mem_ecalloc_amount | 0 |
mem_erealloc_count | 0 |
mem_erealloc_amount | 0 |
mem_efree_count | 0 |
mem_efree_amount | 0 |
mem_malloc_count | 0 |
mem_malloc_amount | 0 |
mem_calloc_count | 0 |
mem_calloc_amount | 0 |
mem_realloc_count | 0 |
mem_realloc_amount | 0 |
mem_free_count | 0 |
mem_free_amount | 0 |
mem_estrndup_count | 0 |
mem_strndup_count | 0 |
mem_estrdup_count | 0 |
mem_strdup_count | 0 |
mem_edupl_count | 0 |
mem_dupl_count | 0 |
proto_text_fetched_null | 0 |
proto_text_fetched_bit | 0 |
proto_text_fetched_tinyint | 0 |
proto_text_fetched_short | 0 |
proto_text_fetched_int24 | 0 |
proto_text_fetched_int | 0 |
proto_text_fetched_bigint | 0 |
proto_text_fetched_decimal | 0 |
proto_text_fetched_float | 0 |
proto_text_fetched_double | 0 |
proto_text_fetched_date | 0 |
proto_text_fetched_year | 0 |
proto_text_fetched_time | 0 |
proto_text_fetched_datetime | 0 |
proto_text_fetched_timestamp | 0 |
proto_text_fetched_string | 0 |
proto_text_fetched_blob | 0 |
proto_text_fetched_enum | 0 |
proto_text_fetched_set | 0 |
proto_text_fetched_geometry | 0 |
proto_text_fetched_other | 0 |
proto_binary_fetched_null | 0 |
proto_binary_fetched_bit | 199 |
proto_binary_fetched_tinyint | 0 |
proto_binary_fetched_short | 518 |
proto_binary_fetched_int24 | 133 |
proto_binary_fetched_int | 0 |
proto_binary_fetched_bigint | 865 |
proto_binary_fetched_decimal | 0 |
proto_binary_fetched_float | 0 |
proto_binary_fetched_double | 0 |
proto_binary_fetched_date | 0 |
proto_binary_fetched_year | 0 |
proto_binary_fetched_time | 0 |
proto_binary_fetched_datetime | 0 |
proto_binary_fetched_timestamp | 0 |
proto_binary_fetched_string | 0 |
proto_binary_fetched_json | 432 |
proto_binary_fetched_blob | 371 |
proto_binary_fetched_enum | 0 |
proto_binary_fetched_set | 0 |
proto_binary_fetched_geometry | 0 |
proto_binary_fetched_other | 0 |
init_command_executed_count | 0 |
init_command_failed_count | 0 |
com_quit | 0 |
com_init_db | 0 |
com_query | 2 |
com_field_list | 0 |
com_create_db | 0 |
com_drop_db | 0 |
com_refresh | 0 |
com_shutdown | 0 |
com_statistics | 0 |
com_process_info | 0 |
com_connect | 0 |
com_process_kill | 0 |
com_debug | 0 |
com_ping | 0 |
com_time | 0 |
com_delayed_insert | 0 |
com_change_user | 0 |
com_binlog_dump | 0 |
com_table_dump | 0 |
com_connect_out | 0 |
com_register_slave | 0 |
com_stmt_prepare | 16 |
com_stmt_execute | 16 |
com_stmt_send_long_data | 0 |
com_stmt_close | 16 |
com_stmt_reset | 0 |
com_stmt_set_option | 0 |
com_stmt_fetch | 0 |
com_deamon | 0 |
bytes_received_real_data_normal | 0 |
bytes_received_real_data_ps | 373175 |
