What is this A/C evaporator valve for?
yjeep
japan
hi
The old evaporator didn't have it.
What is this little valve used for?
Flyer58
Magnolia, Texas
If that's a Schrader valve (tire valve) it's used to test the low pressure or suction side of the system or add freon.
After all these years there's a good chance your coil or the one you're replacing has been changed before and either, or both, are aftermarket and might be slightly different to include the valve or not.
Usually the high and low pressure connectors are on the engine side of the firewall. I don't know anything about AC on the YJ or where the valves are located on the original equipment.
