I have a 1993 YJ 4.0 with countersunk bottom bolt. Where do I find replacement countersunk bolts.
Countersunk?? My lower bolt was just a shorter than the top one. Be sure to use a sealant on the gasket for cooling systems or the coolant may eat through it.
No trouble with bottom bolt contacting belt?That screw does not sound like the right one. Here is a picture of my housing. The Jeep part number is J8121298 but they don't list the size. It's the same for both 2.5L and 4.0L engines.
Hope this helps.
That's why I always kept countersunk in place. Jeep now says countersunk is obsolete. If you have no contact might work for me. Thanks.No trouble with bottom bolt contacting belt?
You should post up a picture to show us what you're talking about. The thermostat on a YJ is never held in place with a philips drive screw and I've never seen them be countersunk either. Sounds like a PO special. Factory setup is standard bolts and no there is no issue with rubbing the belt.
