Sway bar disconnects too long?
SeabeeJosh
Ridgecrest, CA
I recently purchased a set of Skyjacker Quick Disconnect sway bar links, and before I make the swap from factory, I put the Skyjackers up to the original. The Skyjackers are about 2" longer. My Jeep has a 2" lift kit. Will the extra length not work? Looks like the worst that would happen is the sway bar would need to swing up a bit, but doesn't look like it will cause any interferance.
Anyone else had this sort of problem?
For a 2" lift, you would want them 2" longer...so I don't see there being a problem. Stock length with a 2" lift puts the sway bar at a weird angle compared to stock because it pulls it down.
