Left rear brake drum Issue
jpjeep26uk
UK
Hi all. When I brake hard or brake sharply in the wet or on gravel, my rear left hand side drum seems to lock and then skids which is a bit of a worry. Anything I should look for when I take the hub off to check the brakes? Thanks everyone. 1989 YJ.
Gilaguy23
Q town New Mexico
Ive had similar issues with my right rear. In my case its the adjusters not working correctly and over tightening on that side. Make sure your e brake cables are releasing correctly, there is no axle seal leakage (90wt) or brake fluid contamination on the shoes. If that looks OK make sure the adjusters are not froze up and there are no groves in the backing plates from the shoes wearing into them. If all that checks out Id carefully blow, brush, hose out the brake dust and readjusting them evenly and see how that does. To me best case is these are short wheel based so hitting the brakes hard in a corner or at speed is gonna be tricky at times.
Reactions: jpjeep26uk
Flyer58
Magnolia, Texas
I once had this years ago and found part of the brake pad had separated from the metal shoe. Each time I stepped on the brakes the loose piece got wedged and would lock up the wheel.
