Knock Question
Jackson LeBlanc
Lake Charles, Louisiana
I have a 1987 4.2 L AMC 258 that my dad rebuilt 4 years ago. He broke the engine in slowly and after about a week the engine developed what sounded like a rod knock. There is also another knocking noise that happens when the clutch is engaged. When the clutch pedal is pressed the knock goes away. I isolated the rod knock to cylinder #1 I’m just not sure if it’s rod knock or piston slap but the knocking gets louder as the engine warms up and the oil gets more viscous. There isn’t any metal in the oil whenever I do changes I’m just concerned and I want to tear into the thing to fix it. I’ll record audio at some point and post it
Reactions: Vigilante Motors
The fact that you hear a knock that improves with the clutch engaged could indicate that the noise isn't solely from the engine itself, as sometimes transmission or clutch components can add to the noise when they aren't properly aligned or lubricated.
The isolating of the knock to cylinder #1 is definitely helpful, but distinguishing between a rod knock and piston slap can be tricky without hearing it. Rod knock typically has a deep, consistent sound that correlates with RPMs, while piston slap usually presents itself as a more irregular sound and can sometimes be more pronounced when cold.
If there's no metal in the oil and regular oil changes are being done, that's a good sign. You might want to try these before tearing into it:
  • Check the oil level and condition: Make sure you're using the correct viscosity oil based on your engine's needs.
  • Check/replace the engine mounts: Sometimes bad mounts can transmit engine noise that sounds like a knock.
  • Inspect the timing chain/belt: Make sure it's not too loose or worn which could contribute to noise.
  • Listen for other sources: Use a mechanic's stethoscope or a long screwdriver to pinpoint the noise source more accurately.
If you decide to dig into it, documenting the process with audio and maybe video can help others assist you or even learn from your experience! Good luck, and keep us updated!
  • Rod Knock typically gets louder as the engine warms up because the oil becomes thinner and provides less cushioning between the rod and crankshaft. If the noise is coming from cylinder #1 and increases with RPM or engine load, it's more likely to be a rod knock.
  • Piston Slap, on the other hand, is more common when the engine is cold and decreases as the engine warms up. It’s usually caused by excessive clearance between the piston and cylinder wall. However, if it’s a persistent knocking sound that gets worse as the engine warms up, it could be rod knock.
  • Check your oil pressure using a manual gauge to confirm that it is within spec. Low oil pressure could make knocking worse as the oil fails to properly lubricate critical engine components.
  • Since the oil is clean and there’s no metal in it, you can rule out significant bearing damage, but that doesn't completely eliminate the possibility of a rod knock.
If you're able to perform a compression test on all cylinders, this could give you a better idea of the health of the engine, especially cylinder #1. Low compression on one cylinder could indicate a rod knock or piston issue.
If you're confident the noise is rod knock and it’s progressively getting louder, a tear-down of the engine to inspect the rod bearings, crankshaft, and pistons would be the next logical step.
As far as the clutch goes, the clutch throw-out bearing could be bad. A worn-out throw-out bearing could cause noise when the clutch is engaged, and the noise might go away when the clutch pedal is pressed because it disengages the bearing.
Possibly the clutch fork or pressure plate as well.
I am very confused with this knocking now. I changed the cylinder #1 and #2 rod bearings and closed that clearance up nicely. I go to start it and after I do it heats up and the same knocking returns. I think the louder knock is something different maybe a main bearing. But the two rod bearings seam to be fine. The knocking quiets down significantly when I accelerate, one big improvement from what the rod knock was doing. Any thoughts?
