1992 Jeep YJ, 2.5, Manual here. Just installed stereo and new dash speakers. All was rusted in and wiring in dash just bundled and wrapped. I cleaned up all the wiring and secured off only utilizing the constant, switched and ground. I ran all new speaker wiring. After finishing the install, the radio came right on and sounds great, yet now the 4wd light is on (first time I've seen it work since I purchased 6 months ago). Please note that I have replaced the dash gauge cluster because none worked, and now all do nicely. I tried unplugging the indicator sensor on the passanger front axle, yet it still on. I tried to plug the vacuum lines, and still on. Any suggestions? Is there something in the dash that I could of disrupted when peeling it back to get speakers out? Does the Sensor switch keep light off when pressed or released? I did see on a thread that sharp turn and vibration means 4wd is stuck, which I have felt a couple times only when parking it.
Thanks,
Ray
Thanks,
Ray
