I am having a helluva time re-installing my 4.2L engine to my AX 15 transmission. I have changed every angle on both the engine and transmission, and can't get the splines to line up, The transmission is in neutral, and I double checked the pilot bearing to make sure it fit. Since it doesn't feel like the splines are lining up , can I use longer bolts to draw them together, figuring the splines will mesh?? Thanks
