Not running the computer emissions anymore. I have a vacuum
Line coming in from fuel tank to first port closest to firewall. Second port is going out to tee w pcv back into carb. Third is purge port. I don’t have a CTO switch or any of that bc the PO started the process of eliminating stuff. I went full hei and mc 2100 to finish it and simplify. Just wondering if I can and if I should cap the raised up purge signal port so I don’t get a vac leak. Will canister still work ok and deal w my fumes
