Well I can't go back and edit what I wrote but yeah the cam will drop onto the bearing surface as you push it through and the lobes will strike the bearing surface. You will need access from underneath to guide the cam along through the bearings. Unless you has something special to keep it perfectly level and prevent it from dropping each time a journal cleared the bearing.
I don't know what I was thinking as I've done this a few times.
