Body Swap, could I put a 1988 body onto a 1993 frame?
jkaardal
Campbell River
I've Just bought my brothers jeep off him, he let it sit for way to long its a 1988 yj safari. the body is in awesome condition. the motor has a blow by issue (4.2l with the old peugot tranny). I have found a 93 yj with the 4.0 and ax15 tranny and am wondering if I can just swap the body from my 88 onto the 93?
Chief Hof
Bordentown, NJ
The answer to your question would be "Yes"...the only variance would be the cut out in the transmission tunnel to the right of the transfer case shifter found on standard transmission equipped YJs in case your current body has an automatic trans installed. Also, a/c equipped YJ bodies have additional holes in the passenger firewall for the a/c unit compressor hoses that would likely need filled in or cut out depending on your current body-to-new body configurations...in the event your new body comes without the roll bar, the '88 roll bar is different from a '93 roll bar, but completely interchangeable...just keep in mind that the bars that attach the windshield frame to the roll bar are adjustable and are set at a specific measurement so that you don't tweak the windshield frame and/or body. Finally, make sure you perform the swap on a level surface...
