I have a 87 YJ 4.2L with the BA10 5 speed transmission. The clutch is making noise when I depress the clutch. So I bought a clutch kit.
Everything looks correct with what I removed but the pilot bearing pressed into the flywheel is larger than the one I got in the kit (or what's left of the original bearing... There are no rollers left in it)
so, do I drill out what's left of the original bearing and press the new one in or do I have to get a larger bearing all together? The plate fits onto the nicely onto the shaft of the transmission and the pilot bearing fits onto the end of the shaft. It's the OD if the new bearing that's not right. What do you suggest?
