My YJ has never had a sway bar and there are times when I wish it did, especially on the freeway. In planning to re-install the stock sway bar/disconnects I looked underneath and found that the bolts where the sway bar would connect on the steering bracket were broken clean off. So I'm at a crossroads now. I can either purchase a stock sway bar set-up, disconnects, and steering bracket or I can get the Currie Antirock set-up. I have aftermarket inner fenders so the sway bar arm should clear. The only thing I would have to do really is weld the tabs on the axle.
Tried searching online for people's thoughts, but it seems a lot of people that do have it are on TJ's and newer models. For what it's worth, people seem to love it. I think it's stated somewhere that it's not as stiff as stock, but it's probably better than not running a sway bar at all, especially on the freeway. Anyone have any experience with it on a YJ? For those that run them, how hard is it to adjust?
